Generation of new RAPID code-lines via SDK
Well, yes. There is no easy way though. You can either do it through RobotStudio SDK by using instruction templates, or using the PCSDK by updating a module textwise (streamwriter or somesuch) and loading it again.
Of the two I usually prefer the RobotStudio SDK Instruction Template way since you keep a somewhat syntactic integrity. The limitation is logic though like IF WHILE or such, then you have to go with the PCSDK approach of text editing.
What you do with the RobotStudio SDK way is to create Instruction Templates of the types that you want to add.
you can do this by code as well if you want but its much harder, in this example you can see them add a rsmoveinstruction using Path.instruction.add
and then sync it to the Virtual Controller. You can do that with action instructions and data declarations as well
So the speeddata would go under sync data declarations and the CirPath stuff would be move instructions or actions instructions depending on.
John
Developer Center0 -
Hello John,
the links don't work, how can I find the documents.
Best Regards
Wolfgang
- 361 IRC5
- 78 OmniCore
- 853 RAPID Programming
- 30 AppStudio
