How do I make a connection between RobotStudio and SQL Server?
Hello, does anyone here know how to make a connection between RobotStudio and SQL Server through Kepserver? Any suggestions, comments or help will be welcome ... Thanks!
I have no idear about make connection between RS and SQL Server... but why not to try to use PC SDK... It is more easier that make connection between PC and sql server..0
Hello dear, thanks for responding. I am new to the topic, I try to create a pallet cell in RobotStudio, my idea is to apply databases to it, through SQL server, and to be able, for example, to differentiate the ID between several possible clients. I do not know if I can explain myself ...0
There is a very handy software, SQL4Automation, if you would like to connect a robot or plc to a sql database.2
