SmartComponent: Text based logic component
Pavel Riabichev
admin
Hi all!
Try my new SmartComponent "LogicExpressionComparer" which allows you to build some text-based logic and evaluate SC properties.
Description:
Only evaluate math when IF is true (Boolean)
Result IF (String) - Contains the result of the evaluation (true/false)
If you have any suggestions for improvments or found any bugs, you may report them in this thread.
/Pavel
Description:
Properties:
IF (String) - Evaluates boolean and logic expressions.
Supports: Parantheses, AND, OR, XOR, <=, >= ==, !=, >, <
Numeric properties are automatically added for other identifiers.
Math Expression (String) - Expression to evaluate.
Supports +, -, *, /, % (reminder), ^ (power), sin, cos, tan, asin, acos, atan, atan2, sqrt, abs, pi.
Result Math Expression (Double) - Contains the result of the evaluation.
Outputs:
Execute IF True (Digital) - Pulses high when IF evaluates true.
Example:
It can be found in RobotApps or RobotStudio add-ins tab.
https://robotapps.robotstudio.com/Details.aspx?fileId=3c75eafe-ac60-4922-9db6-48b474ced943
(16-08-01) uploaded a new version LogicExpressionComparer_v2 where custom properties may not start with a number and may not have the same name as the standard properties. Fixed a bug with parantheses and changed some names.
Added an output signal which will stay set as long as IF is TRUE.
/Pavel
Post edited by Pavel Riabichev on
5
Hello Pavel,
You have created a great smart component but I'm having a slight issue. when using your smart component, robotstudio crashes and becomes non responding. is this a known issue with your smart component?
Kind regards
Hello, No this is not anything I've experienced or heard of. Is there a special situation when this is happening, do you have a p&g that you could send where it is crashing?
/Pavel
Hi, I experienced the same problem. It happens when I change the conditional expression (IF). I use multiple of your components. If you want, I can send you an example project.
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
