Physics tutorials
                    Johannes Weiman
                     admin
                    Hi all,
Video tutorials for physics in RS 6.05 (rigid body dynamics and cable simulation) are now live on http://new.abb.com/products/robotics/robotstudio/tutorials.
Regards,
Johannes
Regards,
Johannes
Johannes Weiman
RobotStudio Team, ABB Robotics
1
            We are so in need of accurate hose simulation right now!!!!!!!!!!!!!!!!! Can't wait to test.0
            Does this mean that we can use physics with grippers in order to simulate picking parts, without needing to resort to Smart Components (for attaching parts to the grippers)?0
            Wow! loooovely! looking forward to test it
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
            Hey! This new physics engine is absolutely awesome!
If RobotStudio was miles above any other Robot Manufacturer simulator, now it is even further high up!
Congratulations are in order for the ABB_RS team!
Thanks and keep up the great work!
Regards,
Rui1 -
            Hi! After couple of hours playing with the new RS6.05... I came with a really good DressPack simulator with the Physics and Hose simulator
Hope you like it.
https://youtu.be/YYanJO-sX24
Daniel Aguilar
            Cool!Johannes Weiman
            Hi again.
I've tried to do the same thing as in the video tutorials of ABB about physics... but is not working same... What I am missing?
https://youtu.be/XLvumSimcsk
Daniel Aguilar
Please, add attach / deteach feature for the start point and the endpoint, or let me modfiy this points in the modify cable dialog.
Thank you.
Klaus Vogel
Kühne+Vogel Sondermaschinen GmbH1 -
            Hi everyone I’m an engineering student. I downloaded RS 6.04 trial version. I want to physics joint but i can’t found in the modelling tab. When I right click to solid object the physics section is gray I can’t click it. Please help me. Best regards0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
