Weld Simulation Errors
I'm trying to simulate some welding in RS, At the end of a weld path I get a "110415 - Weld Off Supervision timeout" Sometimes I can move past the timeout by manually turning on or off the diArcEst_W1_R1 input. Any thoughts on this?
Why don't you try to adjust weldoff timeout value.
/Adnan
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 26 AppStudio
