Absolute accuracy
Dear All,
I'll try to use the ABB Absolute accuracy and wan't to make the measurments with an external calibration vendor.
Has someone experience how to buy only the ABB parameter configuration file without the complete measurement procedure priced 6k€?
Best Regards,Christian
  • lemster68
    lemster68 ✭✭✭
    The parameters are useless without doing the AbsAcc calibration.  The procedure measures the arm deflection under load for each individual robot, not the robot type in general.  So the measurement is what generates the parameters for each AbsAcc robot.
    Lee Justice
