Physics tutorials
Hi all,
Video tutorials for physics in RS 6.05 (rigid body dynamics and cable simulation) are now live on http://new.abb.com/products/robotics/robotstudio/tutorials.
Regards,
Johannes
Johannes Weiman
RobotStudio Team, ABB Robotics
  • We are so in need of accurate hose simulation right now!!!!!!!!!!!!!!!!!  Can't wait to test.
  • Does this mean that we can use physics with grippers in order to simulate picking parts, without needing to resort to Smart Components (for attaching parts to the grippers)?
  • Wow! loooovely! looking forward to test it :smile:
    Un saludokind regards,
    Daniel Aguilar
    Automation Engineering
  • Hey! This new physics engine is absolutely awesome!
    If RobotStudio was miles above any other Robot Manufacturer simulator, now it is even further high up!
    Congratulations are in order for the ABB_RS team!
    Thanks and keep up the great work!
    Regards,
    Rui
  • daguilar
    daguilar
    edited May 2017
    Hi! After couple of hours playing with the new RS6.05... I came with a really good DressPack simulator with the Physics and Hose simulator
    Hope you like it.
    https://youtu.be/YYanJO-sX24
    Daniel Aguilar
  • Cool!
    Johannes Weiman
  • daguilar
    daguilar
    edited June 2017
    Hi again.
    I've tried to do the same thing as in the video tutorials of ABB about physics... but is not working same...  What I am missing?
    https://youtu.be/XLvumSimcsk
    Daniel Aguilar
  • Hi,
    Please, add attach / deteach feature for the start point and the endpoint, or let me modfiy this points in the modify cable dialog.
    Thank you.
    Klaus Vogel
    Kühne+Vogel Sondermaschinen GmbH
    Thank you.
    +1
    Daniel Aguilar
  • Hi everyone I’m an engineering student. I downloaded RS 6.04 trial version. I want to physics joint but i can’t found in the modelling tab. When I right click to solid object the physics section is gray I can’t click it. Please help me. Best regards
    Thank you.
    +1
