Library with geometry and virtual controllers; Solution Library?
Hello all,
I would like to make a library with complete solutions that I can import to a station.
This would be geometry with some robots and a Virtual Controller connected to it. This will give me the possibility to quickly create a bigger station with several controllers.
When I look through the libraries I find the 'Solution Library', but its "unavailable" at my pc.
Does anyone know a solution for my problem?
Best Regards,
Cees-Jan Braam
Best Regards,
Cees-Jan Braam
Mine is grey too, I can't click it
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
When creating a station you have to choose eather Solution with Empty Station or Solution with Station and Robot Controller and then your Solution Library will be enabled.
Go to Import Library-Locations to see where the folder is located.
- 367 IRC5
- 858 RAPID Programming
