Rename file using date at the end of the string. My code is included.
I'm currently writing timestamped data to a text file. Then, pulling the data from the text file for an excel spreadsheet. I would like to be able to use a RESET event routine to save that text file with a new name using the current date at the end of the name. Am I able to do this? rSaveAndClear is the proc I would like to be triggered by the event. Ideally, I copy/rename the current text file (17_ALLI_0192.txt), add the current date to the end (17_ALLI_0192_20170531.txt) and remove all data from the old one.
PERS num nGoodCycles;
VAR String Date;
PERS num WeekDay;
PERS num Hour;
PERS num Minute;
PERS num Second;
VAR iodev logfile;
PROC rGoodCycleCount()
Incr nGoodCycles;
Date:=CDate();
WeekDay:=GetTime(\WDay);
Hour:=GetTime(\Hour);
Minute:=GetTime(\Min);
Second:=GetTime(\Sec);
rWriteGoodCycleDayShift;
RETURN;
PROC rWriteGoodCycleDayShift()
Open "HOME:/" \File:= "17_ALLI_0192.txt", logfile\append;
Write logfile, "GOOD CYCLE"\nonewline;
Write logfile, "*"+Date\nonewline;
Write logfile, "*"\Num:=Hour\nonewline;
Write logfile, ":"\Num:=Minute\nonewline;
Write logfile, ":"\Num:=Second;
Close logfile;
RETURN;
PROC rSaveAndClear()
RenameFile "Home:/17_ALLI_0192.txt", "Home:/17_ALLI_0192_JOB_END.txt"; <--------Can I add in the date during the rename????
Open "HOME:/" \File:= "17_ALLI_0192.txt", logfile\write;
Write logfile, " ";
Close logfile;
RETURN;
Welcome!
  • I'm open to making new directories or an adjacent method that accomplishes the goal.
  • Hi
    You already have a variable with the date so you can just concatenate that on the end of your new file name - as below:
    RenameFile "Home:/17_ALLI_0192.txt","Home:/17_ALLI_0192_JOB_END.txt"+date;
    Regards
    Graeme
  • Hi
    Regards
    Graeme
    Thank you for the response Graeme!
    I used the code you provided and it didn't quite work as anticipated.
    It only added +Date to the end.
    -Rick
  • Graeme!
    You used a word (concatenate) I hadn't heard before.
    After searching the manuals for this word I discovered what you were saying.
    I changed my code in the following way:
    Date:=CDate();<-----I was missing this to request the date again
    RenameFile "Home:/17_ALLI_0192.txt", "Home:/17_ALLI_0192_"+Date+".txt";<---I had to change to this format to get the file to save correctly.
    Write logfile, " ";
    Close logfile;
    RETURN;
    Thank you very much for your response!
    My life has just been made much easier!
  • Hello,
    I am doing this same thing.
    and I haven't been able to load or unload a ".txt", ".Doc" or a ".Log" through my network connection. Is it possible to load or unload these files from the Home directory?
    Thanks in advance.
  • This is the code I've been using to write to a "*.txt" file in my HOME directory.
     PERS num Hour;
     PERS num Minute;
     PERS num Second;
    Incr nGoodCycles;
    Date:=CDate();
    rWriteGoodCycle;
    RETURN;
    PROC rWriteGoodCycle()
    Open "HOME:/" \File:= "17_BORG_3027.txt", logfile\append;
    Write logfile, "1"\nonewline;
    Write logfile, "\\t"+Date\nonewline;
    Write logfile, "\\t"\Num:=Hour\nonewline;
    Close logfile;
    RETURN;
  • nezzreth
    nezzreth
    edited June 2017
    I also use this code in my system module. I trigger it with an event routine RESET:rSaveAndClearEvent
     VAR String Date;
     VAR iodev logfile;
     VAR dir directory;
     VAR string filename;
     VAR string name;
     VAR num nNameLength;
     VAR num nStringLength;
     VAR string part;
      PROC rSaveAndClearEvent()
    rSearchDir "HOME:/TEMPDATA","rSaveAndClear";
    PROC rSearchDir(string dirname, string actionproc)
    IF IsFile(dirname \Directory) THEN
    OpenDir directory, dirname;
    WHILE ReadDir(directory, filename) DO
    ! .. and . is the parent and resp. this directory
    IF filename <> ".." AND filename <> "." THEN
    rSearchDir dirname+"/"+filename, actionproc;
    ENDIF
    ENDWHILE
    CloseDir directory;
    ELSE
    %actionproc% dirname;
    ENDIF
    ERROR
    RAISE;
    PROC rSaveAndClear(string filename)
    IF FileSize(filename) > 1024 THEN
    Date:=CDate();
    nStringLength:=StrLen(filename);
    nNameLength:=nStringLength-19;
    part:=StrPart(filename,16,nNameLength);
    RenameFile filename, "Home:/ERRORDATA/"+part+"_"+Date+".txt";
    Open filename, logfile\write;
    Write logfile, " ";
    Close logfile;
            ENDIF
    RETURN;
    Post edited by nezzreth on
Welcome!
