Rename file using date at the end of the string. My code is included.
nezzreth
I'm currently writing timestamped data to a text file. Then, pulling the data from the text file for an excel spreadsheet. I would like to be able to use a RESET event routine to save that text file with a new name using the current date at the end of the name. Am I able to do this? rSaveAndClear is the proc I would like to be triggered by the event. Ideally, I copy/rename the current text file (17_ALLI_0192.txt), add the current date to the end (17_ALLI_0192_20170531.txt) and remove all data from the old one.
PERS num nGoodCycles;
VAR String Date;
PERS num WeekDay;
PERS num Hour;
PERS num Minute;
PERS num Second;
VAR iodev logfile;
PROC rGoodCycleCount()
Incr nGoodCycles;
Date:=CDate();
WeekDay:=GetTime(\WDay);
Hour:=GetTime(\Hour);
Minute:=GetTime(\Min);
Second:=GetTime(\Sec);
rWriteGoodCycleDayShift;
RETURN;
PROC rWriteGoodCycleDayShift()
Open "HOME:/" \File:= "17_ALLI_0192.txt", logfile\append;
Write logfile, "GOOD CYCLE"\nonewline;
Write logfile, "*"+Date\nonewline;
Write logfile, "*"\Num:=Hour\nonewline;
Write logfile, ":"\Num:=Minute\nonewline;
Write logfile, ":"\Num:=Second;
Close logfile;
RETURN;
PROC rSaveAndClear()
RenameFile "Home:/17_ALLI_0192.txt", "Home:/17_ALLI_0192_JOB_END.txt"; <--------Can I add in the date during the rename????
Open "HOME:/" \File:= "17_ALLI_0192.txt", logfile\write;
Write logfile, " ";
Close logfile;
RETURN;
I'm open to making new directories or an adjacent method that accomplishes the goal.0
You already have a variable with the date so you can just concatenate that on the end of your new file name - as below:
RenameFile "Home:/17_ALLI_0192.txt","Home:/17_ALLI_0192_JOB_END.txt"+date;
Regards
Graeme
1 -
graemepaulin said:
Regards
Graeme
I used the code you provided and it didn't quite work as anticipated.
It only added +Date to the end.
-Rick0 -
Graeme!
You used a word (concatenate) I hadn't heard before.
After searching the manuals for this word I discovered what you were saying.
I changed my code in the following way:PROC rSaveAndClear()Date:=CDate();<-----I was missing this to request the date againRenameFile "Home:/17_ALLI_0192.txt", "Home:/17_ALLI_0192_"+Date+".txt";<---I had to change to this format to get the file to save correctly.Open "HOME:/" \File:= "17_ALLI_0192.txt", logfile\write;Write logfile, " ";Close logfile;RETURN;ENDPROC
Thank you very much for your response!
My life has just been made much easier!0 -
I am doing this same thing.
and I haven't been able to load or unload a ".txt", ".Doc" or a ".Log" through my network connection. Is it possible to load or unload these files from the Home directory?
Thanks in advance.
This is the code I've been using to write to a "*.txt" file in my HOME directory.
PERS num nGoodCycles;PERS num Hour;PERS num Minute;PERS num Second;PROC rGoodCycleCount()Incr nGoodCycles;Date:=CDate();WeekDay:=GetTime(\WDay);Hour:=GetTime(\Hour);Minute:=GetTime(\Min);Second:=GetTime(\Sec);rWriteGoodCycle;RETURN;ENDPROCPROC rWriteGoodCycle()Open "HOME:/" \File:= "17_BORG_3027.txt", logfile\append;Write logfile, "1"\nonewline;Write logfile, "\\t"+Date\nonewline;Write logfile, "\\t"\Num:=Hour\nonewline;Write logfile, ":"\Num:=Minute\nonewline;Write logfile, ":"\Num:=Second;Close logfile;RETURN;ENDPROC0 -
I also use this code in my system module. I trigger it with an event routine RESET:rSaveAndClearEventVAR String Date;VAR iodev logfile;VAR dir directory;VAR string filename;VAR string name;VAR num nNameLength;VAR num nStringLength;VAR string part;PROC rSaveAndClearEvent()rSearchDir "HOME:/TEMPDATA","rSaveAndClear";ENDPROCPROC rSearchDir(string dirname, string actionproc)IF IsFile(dirname \Directory) THENOpenDir directory, dirname;WHILE ReadDir(directory, filename) DO! .. and . is the parent and resp. this directoryIF filename <> ".." AND filename <> "." THENrSearchDir dirname+"/"+filename, actionproc;ENDIFENDWHILECloseDir directory;ELSE%actionproc% dirname;ENDIFERRORRAISE;ENDPROCPROC rSaveAndClear(string filename)IF FileSize(filename) > 1024 THENDate:=CDate();nStringLength:=StrLen(filename);nNameLength:=nStringLength-19;part:=StrPart(filename,16,nNameLength);RenameFile filename, "Home:/ERRORDATA/"+part+"_"+Date+".txt";Open filename, logfile\write;Write logfile, " ";Close logfile;ENDIFRETURN;ENDPROCPost edited by nezzreth on0
- 304 PowerPacs
- 356 IRC5
- 76 OmniCore
- 851 RAPID Programming
- 26 AppStudio
