Import geometry RobotStudio 6.05 failure
DavidR
DavidR
edited May 2017 in UpFeed
Hi. Me and my colleagues are having problems with import of geometries in RobotStudio 6.05 SP1, mostly step files as far as I know.
/David
  • FYI: same file can be imported in 6.04.01, let me know if you want me to send the file in question.
    /David
  • I have the same issue, and same here, the file is working in 6.04.01.
  • Problem signature:
      Problem Event Name: APPCRASH
      Application Name: RobotStudio.exe
      Application Version: 6.5.7392.129
      Application Timestamp: 590c31c5
      Fault Module Name: KERNELBASE.dll
      Fault Module Version: 6.1.7601.23796
      Fault Module Timestamp: 59029714
      Exception Code: c0000005
      Exception Offset: 000000000001a06d
      OS Version: 6.1.7601.2.1.0.256.4
      Locale ID: 2057
      Additional Information 1: 4ef8
      Additional Information 2: 4ef88ca94242e9ac81c15eb87d7f5d07
      Additional Information 3: 14fc
      Additional Information 4: 14fc43fdcbee000477909e37b3308d2d
    Read our privacy statement online:
    If the online privacy statement is not available, please read our privacy statement offline:
      C:\Windows\system32\en-US\erofflps.txt
  • Hi,
    An updated third-party component has caused multiple issues with CAD import in RS 6.05. We will revert to an older version in 6.05.01 .
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • When will 6.05.01 be released?
  • RobotWare 6.05.01 will be released july 7th and usually RobotStudio is released at the same time but I'm not sure.
  • ok, thanks David :)
