How to connect the Emergency STOP Signal to an interrupt routine?
Yishin
I would like to connect the Emergency STOP Signal to an interrupt routine.
Is the following code snippet the right approach?
VAR intnum sig1int;
PROC main()
CONNECT sig1int WITH iroutine1;
ISignalDi di1,sig1int;
PROC main()
Where could I find the definition for Emergency STOP Signal, and all the other signals, like EVENT_STOP, di1, ... etc ?
-Yishin
As the Emergency Stop is a safety signal you should wire it into the safety board (top right hand side of a single controller).
Hi Graemepaulin,
Where could I get the "signal controller" with RobotStudio?
Please tell me the sequence to open it,
Is it opened with RobotStudio -> Controller -> Remote-IRB-Controller -> Configuration -> I/O System -> Configuration ?
Thanks for your reply
You will need to use the system output emergency stop - this is configured as you describe above.
Add the digital output signal (can be a virtual signal), then add the system output using this signal - see screen grab - where the signal I created was called E_Stop.
- 365 IRC5
- 84 OmniCore
