Import geometry RobotStudio 6.05 failure
FYI: same file can be imported in 6.04.01, let me know if you want me to send the file in question.
/David0 -
I have the same issue, and same here, the file is working in 6.04.01.0
Problem signature:Problem Event Name: APPCRASHApplication Name: RobotStudio.exeApplication Version: 6.5.7392.129Application Timestamp: 590c31c5Fault Module Name: KERNELBASE.dllFault Module Version: 6.1.7601.23796Fault Module Timestamp: 59029714Exception Code: c0000005Exception Offset: 000000000001a06dOS Version: 6.1.7601.2.1.0.256.4Locale ID: 2057Additional Information 1: 4ef8Additional Information 2: 4ef88ca94242e9ac81c15eb87d7f5d07Additional Information 3: 14fcAdditional Information 4: 14fc43fdcbee000477909e37b3308d2dRead our privacy statement online:If the online privacy statement is not available, please read our privacy statement offline:C:\Windows\system32\en-US\erofflps.txt0
An updated third-party component has caused multiple issues with CAD import in RS 6.05. We will revert to an older version in 6.05.01 .
Regards,
Johannes
Johannes Weiman
When will 6.05.01 be released?0
RobotWare 6.05.01 will be released july 7th and usually RobotStudio is released at the same time but I'm not sure.0
ok, thanks David0
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
