Why Error 40322 appears when creating a station and loading?
Hi guys, I get the "40322 error" "RAPID syntax errors". I just create a station and add a controller from design. I only happen with the new version of RobotStudio (v6.05), with the previous (v6.04), everything was going well. I hope I can help, otherwise I will have to install the other version ... Thanks!
There's a problem with the Spanish translation of the "Main" module that is automatically added. You can just delete it and everything should be fine.
Johannes Weiman
RobotStudio Team, ABB Robotics1
Dear JWeiman, thank you for your response, it was a great help!0
