Which RS .dll i could use to export station?
billan
Hello everyone!
I have already create an a new tab at RS.I would like to use this tab with a button event inside and when the event called the current station would be export to a specific folder!
As i told before i have already create the tab with button event but i don't know which specific .dll i could use to export the station.(I am new with RS )
Thank you
Hi Billan,
I believe you need to scan the network using NetworkScanner class to see the available controllers on the network and specify which one you want to communicate with. You can find this class in ABB.Robotics.Controllers.PC.dll.0
- 365 IRC5
- 84 OmniCore
