Create WobJ
Hi.All
Possible if create work object without Flexpendant?
How if possible?
Thanks you.
  • Yes via RobotStudio:
    - Create it on your station
    - Transfer it to your virtual system
    - Copy the definition of the new wobj from the virtual system to the real controller. You need to be connected to the IRC5 to do this either from service point or LAN.
  • Hi,ko414du4
    Thanks you.
    Have any more ?
    I mean used command or function  create it.
