Finding coordinates x,y,z of circle center point.
Hello.
Could someone have a code in RAPID for finding coordinates x,y,z of a circle center created from 3 points A,B,C in wobj0.
  • Hi!
    If you still have trouble with this you can try the following code. Circle3P function computes circle center, axis and radius for the given three perimeter points p1, p2 and p3. I tested this a bit and it seemed to work fine. Note that this only works on new RobotWare because it uses MatrixSolve function.
    BR, Keke
    MODULE MainModule<br>&nbsp; <br>&nbsp; CONST num nEPSILON:=1e-6;<br>&nbsp; <br>&nbsp; PROC main()<br>&nbsp;&nbsp;&nbsp; VAR pos p1;<br>&nbsp;&nbsp;&nbsp; VAR pos p2;<br>&nbsp;&nbsp;&nbsp; VAR pos p3;<br>&nbsp;&nbsp;&nbsp; VAR pos c;<br>&nbsp;&nbsp;&nbsp; VAR pos a;<br>&nbsp;&nbsp;&nbsp; VAR num r;<br>&nbsp;&nbsp;&nbsp; VAR bool b;<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; p1:=[200,0,100];<br>&nbsp;&nbsp;&nbsp; p2:=[0,0,100];<br>&nbsp;&nbsp;&nbsp; p3:=[0,200,100];<br>&nbsp;&nbsp;&nbsp; b:=Circle3P(p1,p2,p3,c,a,r);<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; Stop;<br>&nbsp; ENDPROC<br>&nbsp; <br>&nbsp; FUNC num Max(num n1, num n2)<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !Return maximum of two numbers<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; IF n1 > n2 THEN<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; RETURN n1;<br>&nbsp;&nbsp;&nbsp; ELSE<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; RETURN n2;<br>&nbsp;&nbsp;&nbsp; ENDIF<br>&nbsp; ENDFUNC<br>&nbsp; <br>&nbsp; FUNC num PosLength(pos p)<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !Length of a vector (pos)<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; VAR num nL;<br>&nbsp;&nbsp;&nbsp; nL:=sqrt(Max(0,p.x*p.x+p.y*p.y+p.z*p.z));<br>&nbsp;&nbsp;&nbsp; RETURN nL;<br>&nbsp; ENDFUNC<br>&nbsp; <br>&nbsp; FUNC pos CrossProd(pos p1,pos p2)<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !Calculate cross product for vectors p1 and p2.<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; VAR pos px;<br>&nbsp;&nbsp;&nbsp; px:=[0,0,0];<br>&nbsp;&nbsp;&nbsp; px.x:=p1.y*p2.z-p2.y*p1.z;<br>&nbsp;&nbsp;&nbsp; px.y:=p2.x*p1.z-p1.x*p2.z;<br>&nbsp;&nbsp;&nbsp; px.z:=p1.x*p2.y-p2.x*p1.y;<br>&nbsp;&nbsp;&nbsp; RETURN px;<br>&nbsp; ENDFUNC<br>&nbsp; <br>&nbsp; FUNC bool Circle3P(pos p1,pos p2,pos p3,INOUT pos center,INOUT pos axis,INOUT num radius)<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !Calculate center point, axis and radius for a circle formed by <br>&nbsp;&nbsp;&nbsp; !three point p1, p2 and p3. Axis is unit vector.<br>&nbsp;&nbsp;&nbsp; !Returns True if found, False if points are on a on a single line (infinite radius).<br>&nbsp;&nbsp;&nbsp; !--------------------------------<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; VAR pos v12;<br>&nbsp;&nbsp;&nbsp; VAR pos v23;<br>&nbsp;&nbsp;&nbsp; VAR pos px;<br>&nbsp;&nbsp;&nbsp; VAR pos p12mid;<br>&nbsp;&nbsp;&nbsp; VAR pos p23mid;<br>&nbsp;&nbsp;&nbsp; VAR pos n12;<br>&nbsp;&nbsp;&nbsp; VAR pos n23;<br>&nbsp;&nbsp;&nbsp; VAR pos diff;<br>&nbsp;&nbsp;&nbsp; VAR num l;<br>&nbsp;&nbsp;&nbsp; VAR dnum A{3,3};<br>&nbsp;&nbsp;&nbsp; VAR dnum b{3};<br>&nbsp;&nbsp;&nbsp; VAR dnum x{3};<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; center:=[0,0,0];<br>&nbsp;&nbsp;&nbsp; axis:=[0,0,0];<br>&nbsp;&nbsp;&nbsp; radius:=0;<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; v12:=p2-p1;<br>&nbsp;&nbsp;&nbsp; v23:=p3-p2;<br>&nbsp;&nbsp;&nbsp; px:=CrossProd(v12,v23);<br>&nbsp;&nbsp;&nbsp; l:=PosLength(px);<br>&nbsp;&nbsp;&nbsp; IF l<nEPSILON THEN<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; RETURN FALSE;<br>&nbsp;&nbsp;&nbsp; ENDIF<br>&nbsp;&nbsp;&nbsp; px:=(1.0/l)*px;<br>&nbsp;&nbsp;&nbsp; axis:=px;<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; p12mid:=p1+0.5*v12;<br>&nbsp;&nbsp;&nbsp; p23mid:=p2+0.5*v23;<br>&nbsp;&nbsp;&nbsp; n12:=CrossProd(v12,axis);<br>&nbsp;&nbsp;&nbsp; n23:=CrossProd(v23,axis);<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; A:=[[NumToDnum(v12.x),NumToDnum(v12.y),NumToDnum(v12.z)],<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; [NumToDnum(v23.x),NumToDnum(v23.y),NumToDnum(v23.z)],<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; [NumToDnum(axis.x),NumToDnum(axis.y),NumToDnum(axis.z)]];<br>&nbsp;&nbsp;&nbsp; b:=[NumToDnum(DotProd(v12,p12mid)),NumToDnum(DotProd(v23,p23mid)),NumToDnum(DotProd(axis,p2))];<br>&nbsp;&nbsp;&nbsp; MatrixSolve A,b,x;<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; center:=[DnumToNum(x{1}),DnumToNum(x{2}),DnumToNum(x{3})];<br>&nbsp;&nbsp;&nbsp; diff:=center-p1;<br>&nbsp;&nbsp;&nbsp; radius:=PosLength(diff);<br>&nbsp;&nbsp;&nbsp; !<br>&nbsp;&nbsp;&nbsp; RETURN TRUE;<br>&nbsp; ENDFUNC<br>ENDMODULE
