Error 50138 & 50139 Arm check point limit
techieme
Hello all,
We have a IRB360 with PickMaster 3 option. When I jog the robot manually, I keep getting error 50138 and 50139 regarding "Arm check point limit". How do I rectify the situation? Help please.
Thank you.
Thank you.
hi,
you can update revolution counters for all axis.0 -
I once had the same issue and it turned out that the robot is trying to get to positions where it is out of the limit. In this case, I was not setting the infeed workobject properly. I found out by jogging the robot manually and saw that the position registered for that wobj is not out by far. I recalibrated the wobj and it worked just fine.0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
