Simple Arc Welding PowerPack Example
I'm having a hard time understanding how to create welds using the powerpack.  Is there an example of creating a simple solution in RS?
  • I'm not sure if this is what you are looking for but if you go into robot studio and select the RAPID tab there is a tool called snippet and it will give you examples of arc welding code.
