update revolution counter
i need to update the revolution counter from robotic studio online instead of the flex pendant.
is that is possible ?
thanx
thanx
I dont know if this will work but you can try flex pendant viewer to make a screen for it(Controller/FlexPendant/ScreenMaker) and do there. If that is what you need.0
no, not possible. You need to do this from the flex or teachpendant.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
