ABB OPC Server 6.05 on Windows Server 2012 doesn't work??
I've installed ABB OPC Server 6.05 on an server running Windows Server 2012.
After installation I started the configuration file and was able to find all the robots.
I made the configuration and started the ABB OPC Server.
After that we could browse the robots and configurate the tags we would like to use on the customers OPC Client.
But.
After a restart of the server running the software  the ABB OPC Server doesn't start.
And the tags are unreadable.
So I start the configuration and then I start the ABB OPC Server from there.
Still not able to read the tags from the customers OPC Client.
So I delete the configuration inside ABB OPC Server and make the configuration from again.
After that and start of ABB OPC Server the tags are readable inside the customers OPC Client again.
So, now we need to make the configuration every time the server is restarted and the start ABB OPC Server to make it run.
After that everything works untl next restart.
Is there anyone who have had the same problem or have any experience running ABB OPC Server on Windows Server 2012??
//Mattias
  • there are windows settings to check, as listed in the OPC server manual (available in the application manuals, PC software).   Try those out.
