Option to disable Follow Program Pointer by default
I would like to request an option to disable the Follow Program Pointer by default. Whenever you login to a robot during production or during simulations, you often want to focus on a specific piece of code. To do that, you always need to disable the follow program pointer option. Otherwise, you keep jumping all over the code.
I'd say >95% of the time I would like to -not- follow the program pointer. To me this is probably the most annoying thing in robotstudio, to always have to disable the follow program pointer. I would therefore like an option to change the default behaviour to "Do not Follow Program Pointer".
Kind regards,
Snampo
