Not able to install the SLP Distributor Server
AshwiniD
I am unable to install the SLP Distributor Server in order to activate the network license.
Also, what does it mean in the operating manual chapter 1.3 page 47: "You can install the SLP Distributor server from the Utilities\SLP Distributor directory of the RobotStudio distribution."
Thanking you in anticipation.
Ashwini
Ashwini
They mean a copy of the SLP software is available from that directory.
You install this SLP software on the server/PC that will act as the license server, then activate the license.
1 -
@graemepaulin Thanks heaps!0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 26 AppStudio
