Test signal number
i am trying to log motors positions/speeds and torques from the Tune master log signal utility.
Up to now we managed to log just the torques using 2000 as test signal number.
How do we get positions and speeds?
Is there a list of test signal numbers?
  • Hi,
    it depends on version of Robotware. At least that is what I suppose after searching and trying a few things.
    If you have Robotware 6.05 you can use these numbers I got on other forum.
    "The following test signals are available for both robot and additional axes and are predefined in the system. All data is measured on the arm side of the axis.
    Test signal           Value    Unit
    Position                4000     degrees
    Speed                   4001     degrees/second
    Torque                  4002     Nm
    External Torque    4003     Nm"
    This is from rapid manual for version 6.05.
    I currently fight with the same issue as you. I need to read speed signal for each axis on Robotware 6.01. If you find something more than this what I pasted above I would really
    appreciate.
    Wojtek
  • Hi,
    Torque                  4002     Nm
    appreciate.
    Wojtek
