Can I, with pickmaster, get at signal every time a box, that is not used, passes the robot?
I have a system, where 3 robots puts items in boxes on a conveyor.
once in a while, a box passes bye without being used by the robots, so the box is empty.
Is there a way to get a signal, when this happens?
  • If it is PM3 take a look at rapid instruktion flowcount
    Regards
    Knud Erik Lindberg
    Danrobotics
  • I'm actually found that after I wrote my question.
    But I found out, that I need to do that in a background task.
    So now I need to share the source variable to get it to work. How can I do that?
