Align Orient a position on a reference orientation and lock the Z axis
I try to realize the align orientation to position in Rapid language. (Function that exists through the robotstudio interface) oriented towards the reference position
I want to align the orientation by blocking the Z axis
The z axis of my tool is not aligned with tool0. The tool is a milling cutter. I want the wrist always to stay in the same direction. The tool is rond.
if I change the angle Z this influences the angles X and Y. Because the convention Roll Pitch Raw
My idea is :
1 - make off-line tangent trajectories
2 - In langage Rapid compensating the diameter tool
3 - Align Orient on a reference orientation
4 - Execute the trajectory
The change the diameter tool is easy. Not modifie trajectory off-line
I succeeded after a good night's sleep0
Would you be able to share your RAPID code to achieve something similar to "align target orientation" in RAPID?LeCabellec said:I succeeded after a good night's sleep
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 33 AppStudio
