Y axis speed low
Hello ,
            I got a problem run robot in auto mode, when I run my program in RS, the speed seems normal, but when I run programs in auto mode one of the orders runs weird: y axis runs very slow , I indeed set the velocity to v2000, but it runs not like 2000, more like a low speed , but in RS its a high speed , I don’t know if there some limits in FP or somewhere , somebody tells me that’s because axis1 can’t run in high speed ,I don’t if it’s true , but the problem is I can’t speed up in one y axis movement , that weired.
           code as below:
           MoveL pGlue25, v2000, z5, tGlueGun\WObj:=Obrenew;
           This in RS is high speed but slow in real world,  if there some limits please tell me
           Thank you very much
  • Do you have a large reorientation? Any reorientation?
    Lee Justice
    Thank you very much, but no, there's no any reorientation, it's a glue system, TCP stays the same orientation in the whole paths,
    and I found that the other instructions stay low speed, but in RS robot can speed up to specific speed , I don't know if I can trust RS simulation result or theres any difference between RS and real world
  •        I think I figured out whats wrong with this ,       -Signal "vdiLimitSpeed" -Action "LimitSpeed" -Arg6 "ROB_1"
           SpeedLimit actived, so robot stays very slow speed.
