UAS Grants - "Go To" function while Jogging
A client requested us to set up user levels on his Flexpendant so that operators could not accidentally edit code or positions.
This has happened in the past, resulting in a crash.
At this point the operator (Default User) has no rights anymore.
This still allows him to jog the robot, but all the other options are blocked.
The only problem now is, is that the "Go To" function in the Jogging Menu is blocked as well.
In the manual I can not find any information about activating/deactivating this option.
Does anyone know how to reactivate this?
To which "Controller Grant" in the UAS is this 'Go To' function linked?
Thanks in advance.
Regards,
Willem
