update revolution counter
i need to update the revolution counter from robotic studio online instead of the flex pendant.
is that is possible ?
thanx
  • I dont know if this will work but you can try flex pendant viewer to make a screen for it(Controller/FlexPendant/ScreenMaker) and do there. If that is what you need.
  • no, not possible. You need to do this from the flex or teachpendant.
