I can't change the IP Settings of the robot
jerry-licao
Hello every one :
I have encountered a problem when setting the IP address , it said the IPcan't applied to the controller , I have successfully changed the IP before ,anyone have any idea ?thanks
hi,
Make the default gateway the same as your IP adress. That will solve your problem
Hope this helps0 -
But you may have to make the last number of the default gateway a 1.0
