SDK load SmartComponent
I have created a GraphicComponent group in an addin and wish to programmatically to add a PositionSensor from the standard RS SmartComponent Library. How do I do this and paramatise it (ie set length and size)
Hi Simon, try this:
GraphicComponentGroup myGroup = ...<br> var libPath = Path.Combine(ApiConfiguration.ABBLibraryDirectory, "Components", "LineSensor.rslib");<br> var library = GraphicComponentLibrary.Load(libPath, true);<br> var lineSensor = library.RootComponent.CopyInstance() as SmartComponent;<br> myGroup.GraphicComponents.Add(lineSensor);<br>
The CopyInstance() call is needed to create a modifiable copy of the component.
Regards,
Johannes
Johannes Weiman
RobotStudio Team, ABB Robotics5
Correction I meant a Line Sensor0
