Suggestion: Collapse parent tree
DenisFR
DenisFR ✭✭✭
I suggest in Components tree to collapse parent tree and select it, if you type left arrow key.
And add sub-menu: "Collapse to parent" and "Collapse All".
Thanks.
  • Hi,
    There is already a "Collapse Browser Contents" (= Collapse All) in the  menu.
    Typing left when on an un-expanded node should probably select the parent node (but not collapse it), like in Windows Explorer.
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • DenisFR
    DenisFR ✭✭✭
    Yes, you're right.
  • Added to 6.07
