restore from backup file
haining
hello ,
I tried to restore a robot from the real controller backup file, RS edition is 6.03, and the robot controller is 6.03, but I can see nothing backup information , is there something wrong when I tried to backup the program?
But I can see the backup information when I restore a program which edition is 5.14. I don't know whats wrong with this,
thank you
6.03 backup below:
5.14 backup below:
thank you
6.03 backup below:
5.14 backup below:
Hello anyone?0
I think I figured out what's wrong with this, I should use RobotWare6 , afterwards everything goes well.
thank you all0 -
It looks like your using the robot ware 5 system builder to do it. If the controllers already build then right click it and select restore, if not the build a new controller from a backup using the installation manager0
- 367 IRC5
