RobotStudio Online YuMi on Windows Surface Pro
Hi, I've been trying to install the MS App referred to above onto a brand new Windows Surface Pro, which i understood to be compatible. However the MS app store is blocking the install, even thought the non Yumi version is working etc.
Does anyone have any direct experience installing on Surface Pro, or even a work around?
Many thanks
Many thanks
There was a mistake when the app was published to the Store. A fixed version should be up soon (hopefully today).
Johannes
Johannes Weiman
Fixed.
Johannes Weiman
Thanks, I suspected as much. However I'm still having problems. I can run the normal Windows app like Robot Studio Tune or Jog. But when trying to connect to the same IP address the Robot Studio Online Yumi just crashes out every time.
Tried uninstalling and reinstalling etc, but nothing seems to clear it. So do people have it working yet? Or just a problem at my end?
Thanks0
