Setting the Robot Speed to 100% always
gkumar
Hi I am trying to set up the Robot speed to 100% always even if someone tries to change them from the TP. Is there a way to do this from the Main program ?? I want to do this because I have coordination issues between the conveyor and robot. I am using vision and conveyor tracking.
You can use the instruction SpeedRefresh in a background task.
This requer the option multimove.
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
There could be a way to lock it out on the pendant with user permissions, but unfortunately, the default pendant speed override trumps SpeedRefresh.
Or lock users into a WHILE loop until it's manually changed:
WHILE CSpeedOverride()<>100 DO
ErrWrite "Speed Override Active", "Change speed override back" \RL2:="to 100 percent.";
Stop;
ENDWHILE
I have used this bit of code in the past to check speed override.
nSpeedOride:=CSpeedOverride();WHILE nSpeedOride <> 100 DOTPErase;TPWrite "Speed Override is NOT 100%!!!";TPWrite "Program will run when override is set to 100%.";nSpeedOride:=CSpeedOverride();WaitTime 0.25;ENDWHILELee Justice0
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
