Reading speed of robot axes
I am looking for a way to read values of each robot axes' speed in a station working on Robotware 6.01.
I found out that when I make system with Robotware 6.05 I can use test signals to do it. But when I try to do exact same thing with a system with Robotware 6.01 it doesn't work.
Does anybody know how can I get these signals?
Thanks,
Wojtek
Thanks,
Wojtek
Why not just update the system to 6.05? It is not difficult.Lee Justice0
Have you tried using Signal Analyzer Online in RobotStudio?Henrik Berlin
There were some difficulties but at last the system has been updated. And now I have access to these sign@lemster68
@lemster68
You were right it was the easiest way.
@Henrik Berlin
Signal Analyzer unfortunetaly can't read speed of joints. It can read only TCP speed.
Does anyone know how could I get a Technical reference manual for RobotWare 6.05 now?0 -
In RS, "file" tab, "help", you will find documentation.Lee Justice0
@lemster68
Thanks! I forgot that documentation is also in Help.0
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
