Accessing the base frames via C#
scottMHA
Is there a way of accessing and editing the base frame of a system in c#? I want to check that the base frame is correct for systems but cant find a way of accessing the info.
How do you want access it?
SmartComponent, Add-ins, via PC SDK, ...?
Is it a real controller or virtual?
It going to be a option added to an existing addin to check virtual controllers.0
