custom motion command
Amol
can anyone help me in creating a custom motion command,i need to add a analog output in every motion command
For eg -
For eg -
Is there some reason you do not want to use the Rapid instruction MoveLAO?Lee Justice0
Try this.
MODULE Grind(SYSMODULE,NOSTEPIN,VIEWONLY,READONLY)!***********************************************************!! Module: Unnamed!! Description:! Custom motion proc for Move with analog output!! Author: Lemuel!! Version: 1.0!!***********************************************************CONST robtarget myRobtarget10:=[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];CONST robtarget myRobtarget20:=[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];CONST robtarget myRobtarget30:=[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];PROC GrindL(VAR Robtarget pPos,VAR Speeddata Speed\num Time,VAR zonedata zone,PERS tooldata tool,\PERS wobjdata Wobj,VAR signalAO analog,num value)MoveLAO pPos,Speed\T?Time,Zone,tool\Wobj?Wobj,Signal,value;ENDPROCPROC TestMotion()GrindL myRobtarget10,v100,z10,tool0,AO1,2.5;GrindL myRobtarget20,v200,z50,tool0,AO1,5;GrindL myRobtarget30,v80,z10,tool0,AO1,3.5;ENDPROCENDMODULELee Justice0
- 365 IRC5
