Problem with Station Viewer and RobotStudio Holographic
I have a question about RobotStudio Holographic. I can open the station, but I can´t run the simulation. It doesn´t give me the option to press the "Play" button. Here is a video with a demonstration: https://youtu.be/IwwhG_jf9n8. I attached the file that I am using.
The weird thing about it is, that I also can´t open the file in Station Viewer. I don´t know if these two problems are connected. This is the error that I get:
The tried other stations and the result was the same. Any idea what the problem might be?
Ales
  • Hi,
    What RS version are you using? Can you share the .rsstnv file?
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Oh, sorry, I though I attached it. It should be here now. I´m using the latest version (6.06.01)
  • Hi Ales,
    The viewer file does not contain a recorded simulation as far as I can see.
    To include the simulation you must use Simulation -> Play -> Record to Viewer and select rsstnv when saving the result.
    The second bug is not related and will be fixed in 6.07.
    Regards,
    Johannes
    Johannes Weiman
  • Ok. I´ll try it out the next time I get the Hololens. I saved it with File > Share > Save Station as Viewer.
    Thanks for the help so far
