TemporaryGraphic.Highlight() method not working
zbennett
The method TemporaryGraphic.Highlight() doesn't seem to actually do anything. I was just wondering if this was a known issue or if there was a work around.
What kind of temporary graphic are you using?Johannes Weiman
Sorry I just saw that you responded. I was using a pointcloud temp graphic but I believe I have seen the issue with other types as well. Thanks!0
- 858 RAPID Programming
