I have a question about RobotStudio Holographic. I can open the station, but I can´t run the simulation. It doesn´t give me the option to press the "Play" button. Here is a video with a demonstration:
https://youtu.be/IwwhG_jf9n8. I attached the file that I am using.
The weird thing about it is, that I also can´t open the file in Station Viewer. I don´t know if these two problems are connected. This is the error that I get:
The tried other stations and the result was the same. Any idea what the problem might be?
Ales
