Debug robotstudio using visualstudio 2005(VB)
Knud E Lindberg2008-12-02 14:32:33
How can i use Visualstudio to debug VB code in Robotstudio.
Regards
Knud Erik Lindberg
Danrobotics
Knud Erik Lindberg
Danrobotics
Quite easySelect properties on your project then change output path (build tab) to "where you installed RS"inaddins
Then changed start external program (debug tab) to RobotStudio.exe.
You will now be able to start debug from VSPer Svensson
Consat Engineering0 -
Hi PerThanks
Can i prevent RS from closing when i stop the debuger in vb studio ?Regards
Knud Erik Lindberg
Danrobotics0 -
Well you can attach VS to a running process(like RS) but the issue is that if you want to make modifications on your addin you need to restart RS because the addin is loaded when you start RS.Per Svensson
dear mr. PerSvensson.
I am trying to debug my C# programs. I am using VS2008 and RS6.05.
I applyed the two thinks (outout path, external program) which you mentioned above.
After pressing F5 this appear:
do you have clue what happen or what I forgot to do?
thanks.
It seems like you might have not selected the correct path for the RobotStudio.exe, please check that you have selected the correct file location.lubosko105 said:dear mr. PerSvensson.
thanks.0
- 367 IRC5
- 858 RAPID Programming
