I can't change the IP Settings of the robot
Hello every one :
     I have encountered a problem when setting the IP address , it said the IPcan't applied to the controller , I have successfully changed the IP before ,anyone have  any idea ?thanks
  • hi,
    Make the default gateway the same as your IP adress. That will solve your problem :smile:
    Hope this helps
  • But you may have to make the last number of the default gateway a 1.
