Can I create a button in my toolwindow ,the function of button is same to AutoPath button.
Hello
I'm developing in RobotStudio using C# .I add a "AutoPath" button in my toolwindow,I want the function of the button is same to AutoPath Button in the Home(Tabs)_Path Programmming(Groups).First I try to find the id of the button in the RobotStudio API Reference ,but I cann't find it.
Does anyone have an idea how i make my "AutoPath" button have the same function.
OK,thank you very munch.
Regards,
zhang0
Below is an example of my addin written in C#,to attempt to simulate clicking the "AutoPath" button,but it not work.
Unfortunately,when I click the "AutoPath"button in "Home"Tab,the button losed efficacy that Pop-up "AutoPath"dialog box. Does the software have a bug?
[code]private void AutoPath_Click(object sender, EventArgs e)
{CommandBarButton.FromID("AutoPath").Execute();
}[code]Another question,Have anyone show me that where can I get the "RobotStudioIDSummary.html".
可以告诉以下我怎么把button2事件设置成启动abb的RAPID程序吗0
可以告诉以下我怎么把button2事件设置成启动abb的RAPID程序吗?0
Hi somenasty,
我不知道你具体要用RAPID(Tabs)下面的什么功能。
你可以参考一下下面的代码。如果你要实现这个功能,可以找到它的IDs,然后用formID[]methods,但是不是所有的button都有相应的IDs,我也没有找到这些button的IDs。
[code]
CommandBarControl commandBarControl = UIEnvironment.RibbonTabs["RAPID"].Groups["Controller"].Controls["RapidApplyMenu"];
if (commandBarControl != null)
((CommandBarPopup)commandBarControl).ClickButton.ExecuteCommand += ClickButton_ExecuteCommand;
((CommandBarButton)((CommandBarPopup)commandBarControl).Controls["RapidApplyAll"]).ExecuteCommand += ClickButton_ExecuteCommand;
((CommandBarButton)((CommandBarPopup)commandBarControl).Controls["RapidModuleApply"]).ExecuteCommand += ClickButton_ExecuteCommand;}
Logger.AddMessage(new LogMessage("ONload"));[code]
Regards,
zhang0 -
@zhang: did you get your code for Apply button working with SmartComponent?
I can't.
I code the same for mine (https://github.com/DenisFR/RSDrawGraphics) but this doesn't works.
\RSDrawGraphics\RSDrawGraphics.cs:234
Hi DenisFR,
This is the code you posted on the forum before. But I didn't test it before.Today I get the code for Apply button working with Add-in,it doesn't works.
You can ask the others again.
Regards,
zhang0 -
zhang said:Today I get the code for Apply button working with Add-in,it doesn't works.
Yes, maybe @Henrik Berlin can answer me?
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
