Profinet
Can someone please differentiate between following options??
Option 888-1  Profinet I/O m/s HW  -- hardware option for a DSQC 678 in the PCI slot
Option 888-2  Profinet I/O m/s SW  -- software option for Profinet Master or Slave over the LAN or with other Hardware Option Ethernet Board
Option 888-3  Profinet I/O Slave -- software option for Profinet Slave over the LAN or Ethernt Board hw option
Option 840-3  Profinet I/O -- Profinet Fieldbus Adapter in the USB slot
With Regards,
Gopinath
  • 888-1 is obsolete
    888-2 - SW Option for Profinet Master&Slave. Can be used Existing LAN Port in Main Computer
    888-3 - SW Option for Profinet Slave(only). Can be used Existing LAN Port in Main Computer
    840-3 - HW Option for Profinet Slave(only). Will be using Field Bus Adapter port in Main Computer
