40224: Execution Error
I am receiving this error at random times, I can't track it down...
  • happens when we try to simulate or "move along path"
  • restarted my comp, error is gone for now..........
  • Neily03
    Neily03 ✭✭✭
    Seen that one before, closing and opening RS fixes it, must be another bug.
  • This error is back.
    Now restarting RS does not clear it...
    I have tried multiple RS version and Robotware combinations.  I can't find one that works.
  • So I found that my PaintL commands have become undefined....
    You can see below that when I change PaintL to MoveL, the syntax highlighter recognizes MoveL.  Also you can see where the simulation stops and gives the unrecoverable error.
  • Neily03
    Neily03 ✭✭✭
    What version of RS you running?
  • @Neily03 I've tried 602, 605, 606.
    The tooltip is there when I hover over the PaintL.
    And the module that has the definition code is in the system.
    Weird...
  • Neily03
    Neily03 ✭✭✭
    PaintL is never highlighted in blue like MoveL, just checked and it's in a black font like yours.
  • Interesting.  Yeah everything looks good on my end too.  Everything appears to be define, get no errors when I check program...
  • I tried opening paint power pac, then a save and no save and loading the module through there.
    I got one successful simulation.
