Accidentally deleted system
                    AlexRad
                    I deleted by mistake all teach pendant directories and now when I start the controller it says: "RobotWare Boot Application 3HAC7927 - 6.17, No system is currently loaded in the controller, Please initiate boot sequence!"
How do I reinstall the system?
Is this a huge problem or I can get everything back on fairly easy? (I do not need old programs and data, just for the robot to work).
Thanks,
Alex
Thanks,
Alex
            Do you have any backups? You can recreate your system from a backup in system builder or installation manager, depending on which rw version you had.Lee Justice0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
