Which is the correct angle orientation for ABB 7 Axis robot
Vane
Dear Experts
I have a 6700 robot with abb track. If the robot is installed as follow picture,
where is the wobj0 and the orientation?
As I know wobj0 is under the 7th axis. But I have no idea about the orientation.
Thanks!
Thanks!
Put the coordinate system into workobject with wobj0 active, and jog linear. It should be the same as the robot base.Lee Justice0
