RS 6.07 Safetysignals and SafeMove on VC
Hi!
I want to ask if you can set safetysignals in simulation to SafeMove on an VC? I can set the signal in the simulation tab, but it doesn't seem to be reacting in SafeMove?
/Erik
/Erik
Hello,As I know, SafeMove is not simulated.I've test to trig synchro switch but nothing happens.☑️2024 - RobotStudio® User Group0
Have similar problems this is the problem i have for the moment:
I try to set the signals but doesn't help unfortunately
Would be nice with a fix for this so we can test SafeMove in RobotStudio
/Erik0
- 367 IRC5
- 858 RAPID Programming
