Backup array of robtarget robotstudio
Dear all,
I need to create an array of robtarget (i would like to generate it)
The problem is
WHEN I DO the backup, i cannot found the declaration of the array with all values
WHY ?
Thanks for answer
MODULE Module1
PERS robtarget myRobtarget:=[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];
PERS robtarget myRobtarget2{100};
! Procédure principale
! Ceci est le point d'entrée de votre programme
PROC main()
FOR i FROM 1 TO 100 DO
myRobtarget2{i}:=myRobtarget;
ENDFOR
ENDMODULEI just load it in an empty station, apply the code and then when i go to the flexpendant i could see in data => robtarget => my array of 100 values.The problem is
WHY ?
Thanks for answer
Hello,You have to declare them before:
PERS robtarget myRobtarget2{100}:=[[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]]<br> ,[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]]<br> ,[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]]<br> ...<br> ,[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]]<br> ];
The goal is to be able to decalre array of 2500 values, i would like to avoid to copy it by hands
If you use the FlexPendant (or virtual FlexPendant if a virtual controller), to declare the array it will preload blank robtargets for you.
But here is a limit to the size of the array you can declare via the pendant (can not remember the limit and it is not mentioned in the manuals) - but you can make bigger arrays via RobotStudio.
To preload the targets I copied (in RobotStudio) the maximum that I could declare via the pendant and pasted it (to double the number), then copied the resultant (doubled array) and pasted - you get a very big array quickly this way.
- 365 IRC5
- 84 OmniCore
